Thread: BEST 12" SUBWOOFES FOR - 2.3cuft / 4.6 (total) cuft box 34htz |
Bronze Member Username: Skateguy92
Post Number: 27 Registered: Jul-07
| Posted on Monday, November 17, 2008 - 11:22 pm: |
I just got a new box built that fits flush with the back of my expidition so I was hoping to keep it for a while, it looks very nice. I need to upgrade my woofers though and was wondering which woofers would be BEST to stick in that box. I have around 1000-1500w RMS to work with (stock electrical but 130a alt) Just trying to find out options, dont want to go to the local stereo shop and get bent over backwards. Cliffnotes - need a good 12" woofer (or actually pair) that will play well in a 2.3cuft box tuned to 34htz. Thanks in advance. |
Gold Member Username: Southernrebel
Monroe,
Louisiana
Team Audible...
Post Number: 7074 Registered: Mar-04
| Posted on Monday, November 17, 2008 - 11:26 pm: |
Whats the port area? |
Post Number: 30 Registered: Jul-07
| Posted on Monday, November 17, 2008 - 11:45 pm: |
I had a shop in my town build it for me, they do a good job. The port area is 40.5" |
Post Number: 31 Registered: Jul-07
| Posted on Monday, November 17, 2008 - 11:53 pm: |
I really want a set of RE SX 12's. The RE SE 12's would probably work pretty well right and sound pretty good? |
Monroe,
Louisiana
Team Audible...
Post Number: 7075 Registered: Mar-04
| Posted on Monday, November 17, 2008 - 11:58 pm: |
40.5sqin total? Or 40.5sqin per chamber? If its 40.5 total, you may run into some port noise w/ 2 SX12's. got any pix of the box? |
Gold Member Username: Mendonmafia
Post Number: 1571 Registered: Aug-06
| Posted on Tuesday, November 18, 2008 - 12:00 am: |
sx's will be Very good in that box off of that amplification. i found that slightly smaller 4 net cube box was better because i was bottoming them out but i was running 2k rms and my origional box was 5 cubes net. so basically you will be good. maybe throw a small battery in the back to help keep the voltage up cuz there gonna eat up every last bit of the 1500 rms you have. |
Post Number: 32 Registered: Jul-07
| Posted on Tuesday, November 18, 2008 - 12:08 am: |
its 40.5 total I believe, its a 2 12" box (non seperated chambers) with one port tuned to 34 htz. Heres a pic with a box that is like mine. http://www.autotoysweb.com/images/installs/misc/avalon2.JPG |
Gold Member Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2098 Registered: May-07
| Posted on Tuesday, November 18, 2008 - 10:41 am: |
What about some SoundSplinter RL-p's? |
Post Number: 34 Registered: Jul-07
| Posted on Tuesday, November 18, 2008 - 12:54 pm: |
Im thinking the RL-p's will need more room than I can give them, and they also like to be tuned pretty low right? |
Post Number: 35 Registered: Jul-07
| Posted on Tuesday, November 18, 2008 - 12:57 pm: |
And I totally forgot I would be going for a SQL setup, something I can daily easily. |
Gold Member Username: 420alldaylong
Post Number: 3882 Registered: Sep-06
| Posted on Wednesday, November 19, 2008 - 04:17 am: |
RE SE |
