Home > Message Board > Car Audio > Subwoofers > Archive through November 23, 2008 > I said "F" it,! new plans need help....
Author Thread: I said "F" it,! new plans need help.
Username: Mendonmafia
Post Number: 1582
Ive decided that i dont care about trunk space anymore. im doing a built in box for my next design. i have 3200 rms @ 1 ohm to work with and about 8 cubes ported. Im looking for SQL. i plan on making my electrical powerful enough to let my amp run .5ohm daily so coils aren't to big of an issue.
So what should i get. i know thoes prices on the rd stuff is crazy cheap so i was thinkin of getting thoes 4 spl sonance subs or the pair of alpha 15's.
anyone know which i should go for or if i should go another route. i was also thinking of getting 4 type R's since there so cheap yet can take tons of power.
Username: Insearchofbass
Post Number: 10922
Just a suggestion watch how much weight you put back there. It will put a toll on the suspension as well as the fuel economy.
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1631
I would look into Audiopulse.. they are great with less airspace. You might be able to salvage some trunkspace for amprack and batt's, ect..
Username: Bonhamd
Post Number: 1479
jake papa might still have his axis 15
that would probably do good on that power
Post Number: 1583
im not to concerned about air space anymore. i think im going to do a wall behind the rear seats. either that or im gonna have a 6-8 cube box port and subs firing up.
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1642
Budget?
I still say 2 15"-revo or 1- 15" axis will POUND!
Look at DD or RE or AA or DC. sh!t... there is a lot of ways you can go!
Post Number: 1585
well the subs i listed above i can get for very good deal but i cna only get coils that give me .5ohm so ill probably need to buy 3 batts instead of 2 so i can run my amp at .5 ohms. so if i can get a 1 ohm load i can spend up to $600 on subs.
Post Number: 1588
$600
Username: Kingandsons07
TEAM REVOLUTION
Lincoln,NE
Post Number: 302
4 12" ALPHA's walled now that POUNDS!!!!!!!!!!!!!!!!!!!!
Post Number: 1589
well if i do a well its going to be behind the rear seat's and will be limited 2 3 12's due to there not being enough area for more cone area to fit in the cabin.
i dont have power for 4 aplhas any ways. i only have power for 2.
TEAM REVOLUTION
Lincoln,NE
Post Number: 303
2 15" or 2 12"s what works best the i loved 4 walled hehe
Home > Message Board > Car Audio > Subwoofers > Archive through November 23, 2008 > I said "F" it,! new plans need help.... [ « Previous ] [ Next » ]
