Thread: HDC3 15's setup |
New member Username: Blaze87
Post Number: 1 Registered: Nov-08
| Posted on Thursday, November 20, 2008 - 05:33 am: |
Currently running 2 cvr 15's on a kx1200.1(old setup) I just need to know if this would be a pretty good setup or not. And would it get reallly loud?(new setup below) 2 Audioque HDC3 15's, blazer box width - 37" height - 24" depth - 28" double layered mdf - 1.5" Box tuning 36-38hz @ 5.2 cubes per side 2 6" aero ports per side, facing rear, subs facing top(4 total) Amp AQ3500.1 200a alternator Kinetick 2400 |
Post Number: 4 Registered: Nov-08
| Posted on Thursday, November 20, 2008 - 06:49 am: |
"2 6" aero ports per side, facing rear, subs facing top(4 total)" meant 4 6" aero ports total, subs facing top, and ports facing rear |
Gold Member Username: Rideredder
Cornell,
IL
Post Number: 1507 Registered: Sep-05
| Posted on Thursday, November 20, 2008 - 07:04 am: |
What vehicle is this in? |
Gold Member Username: Stateprop486
PA
Post Number: 1709 Registered: Jan-08
| Posted on Thursday, November 20, 2008 - 08:40 am: |
it should be loud as fu(K |
Gold Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 1670 Registered: May-07
| Posted on Thursday, November 20, 2008 - 09:33 am: |
sounds like you know what you want... You could bump up the amperage on the Alt if you can.. What you got for frontstage? Gonna need a lil extra sound with that sub setup. |
Post Number: 5 Registered: Nov-08
| Posted on Thursday, November 20, 2008 - 06:32 pm: |
its a 87 2door s10 blazer, with older biult 350.but i couldn't find a bigger alt than the 200, cause its the older 1wire style gm alt's.but other than that i have my hdc3's on order, and the 2400 batt on order to. ohh my sound is alpine typer 6x9's back, and typer 6.5 components front, with autotek SM4-1000 125x4, mids and highs get pretty loud and clean this may be a DUMB question, but this should KILL my cvr 15's right? |
Lake Charles,
La.
United States
Post Number: 1685 Registered: May-07
| Posted on Thursday, November 20, 2008 - 07:24 pm: |
The subs are a drastic step up from the cvr's, and you are tripling your power. That being said, It should, but enclosure and install play to big of a factor to say for sure.. I would certainly hope so! |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8994 Registered: Jul-06
| Posted on Thursday, November 20, 2008 - 07:33 pm: |
200 amp alt should be good |
Gold Member Username: Bonhamd
Post Number: 1496 Registered: Nov-07
| Posted on Thursday, November 20, 2008 - 11:05 pm: |
check in to mechman for alternators - ive read nothing but great reviews and the prices are great im putting mine in this weekend www.mechman.com |
Silver Member Username: Ducka
Houghton and/or Macomb,
MI
United States
Post Number: 777 Registered: Jan-08
| Posted on Friday, November 21, 2008 - 11:37 am: |
Yeah if you do that box right it should rap3 your old setup. |
Post Number: 1500 Registered: Nov-07
| Posted on Friday, November 21, 2008 - 12:06 pm: |
pending a good install - this new setup will doodoo on your old one |
