Thread: Upgraded to 4kw |
Silver Member Username: Mmaudioconcepts
Post Number: 584 Registered: Jan-07
| Posted on Thursday, November 20, 2008 - 09:41 pm: |
ok so i upgraded from an 1800wrms to a 4000wrms amp. Im thinking two loaded BL 12s. In the price and performance range what compares to the BLs in overall output and sound quality. |
Gold Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 1696 Registered: May-07
| Posted on Thursday, November 20, 2008 - 10:45 pm: |
Revo's ssi or ssx dc lvl 3 dd 3512 rd alpha re sx idmax si mag rl-s plenty of others |
Gold Member Username: Mgbcs
Maple Grove,
Minnesota
Post Number: 2691 Registered: Dec-06
| Posted on Thursday, November 20, 2008 - 10:48 pm: |
A few of those are a little out of the BL price range. But still a great list  |
Lake Charles,
La.
United States
Post Number: 1697 Registered: May-07
| Posted on Thursday, November 20, 2008 - 10:50 pm: |
some used ;) |
Gold Member Username: Bonhamd
Post Number: 1494 Registered: Nov-07
| Posted on Thursday, November 20, 2008 - 10:58 pm: |
re xxx - i think kevin got his on ca.com for 300 each mmats juggs AQ HDC3 fi BTL dd 9500 you can get some good deals on caraudioclassifieds.com and caraudio.com |
Post Number: 586 Registered: Jan-07
| Posted on Thursday, November 20, 2008 - 11:03 pm: |
how much power do the btls need. off of 2000wrms what has the potential to be better between the BTLs and the BLs |
Gold Member Username: Surferdude9371
Get loud or go home....
Post Number: 1468 Registered: Mar-07
| Posted on Thursday, November 20, 2008 - 11:17 pm: |
off 2kw 2 bls or 1 fully loaded btl off the 4kw |
Silver Member Username: Yukhui
4 15 AA Havocs,
Memphis 4kw!!
Post Number: 975 Registered: Jan-06
| Posted on Thursday, November 20, 2008 - 11:59 pm: |
What vehicle do you plan on putting the system in? |
Gold Member Username: Tejcurrent
Post Number: 1614 Registered: Apr-07
| Posted on Friday, November 21, 2008 - 05:59 am: |
The BTLs should be louder off the given 2000w rms a piece. There was a big long thread on another forum involving sensitivity and other things. |
Post Number: 588 Registered: Jan-07
| Posted on Friday, November 21, 2008 - 10:00 am: |
this particular system is going in a 2000 Grand Prix or an F150 XLT extended cab w/out bck seats. |
Post Number: 1497 Registered: Nov-07
| Posted on Friday, November 21, 2008 - 10:17 am: |
if i had that choice i would put it in the truck - you can get it louder easier maybe bump up to 15s or 18s  |
Post Number: 590 Registered: Jan-07
| Posted on Friday, November 21, 2008 - 10:19 am: |
i have to have a system for both, id like to do the grand prix first. i would do 15s or 18s in the truck. |
Bronze Member Username: Lil_justin850
Justin smith, crestview,
Fl
Okalossa
Post Number: 31 Registered: Sep-08
| Posted on Friday, November 21, 2008 - 11:01 am: |
id say that you listen to troy and then go watch his vids on youtube btls ftw |
Post Number: 1469 Registered: Mar-07
| Posted on Friday, November 21, 2008 - 12:33 pm: |
id do 1 fully loaded btl18 or 2 reg btls |
Post Number: 591 Registered: Jan-07
| Posted on Friday, November 21, 2008 - 03:26 pm: |
im thinking about two BTL 12s now. or I might do a single 15 loaded. |
Post Number: 1503 Registered: Nov-07
| Posted on Friday, November 21, 2008 - 03:48 pm: |
i vote for the 12s if you have the monies |
Post Number: 592 Registered: Jan-07
| Posted on Friday, November 21, 2008 - 03:54 pm: |
should i get any option or just stock |
Post Number: 1506 Registered: Nov-07
| Posted on Friday, November 21, 2008 - 04:14 pm: |
it really depends on what you want to do do you plan on running more to them later on? the options wont hurt you besides the money factor |
Post Number: 1508 Registered: Nov-07
| Posted on Friday, November 21, 2008 - 04:33 pm: |
http://www.caraudioclassifieds.org/forum/showthread.php?t=2099 those could be good pending on what vc config you need |
